Solved
  • Nick's e30
    • Mar 2012
    • 676
    Solved
    As title states. And how much for such a service? Broke my last key off in the lock this evening and can't find my spare.
    Thanks all!
    Nick
    No antenna? I sell plugs!
    Here: https://www.r3vlimited.com/board/sho...77#post4937877
  • Swanny
    • Mar 2012
    • 2834
    Thanks all!
    Nick
    I say take out the tumbler and take out the pieces to a lock smith? Might be cheaper and quicker.
    Or just get a whole new set of locks and keys. They're floatin around here for sale for about 100 bones.
    Swanny!
    SUCKERS.
    • Swanny
      • Mar 2012
      • 2834
      Dude the tumbler takes like 5 minutes to take out. Just need a finishing nail and the key turned to the #2 position (iirc). A lil slot opens up, pop in the nail and TADDA! Locks out!
      Swanny!
      SUCKERS.
      • AZRRC
        • Sep 2012
        • 260
        I took my tumbler out and took to a locksmith, charged me $8 to remove broken key and use both pieces to cut a new one
        89 325i Offroad
        89 325i
        05 C240 Wagon
        • Swanny
          • Mar 2012
          • 2834
          As in the ignition tumbler?
          Correct!
          Swanny!
          SUCKERS.
          • vert_this
            • Feb 2012
            • 395
            yes dealer can make keys with verification of ownership. I have got them to pull my key code before and I take that information to a locksmith cause keys are expensive at the dealer example last key was like less than 10.00 but dealer wanted more than 30.00.
            • vert_this
              • Feb 2012
              • 395
              yeah but they will most likely require u go into the dealer unless u have friends there. I just email it in but I know the parts manager there.
              The locksmith may have a relationship with someone over there that may allow him to b able to fax in verification I dunno.
              They are a lot tighter than they used to be my buddy told me if a car needs a key and the owner has a salvage title BMW will not allow them to pull the code.
              I found this out when a friend bought a wrecked up parts car w/no key.
                My preference is always to get VIN matched keys and/or lock cylinders from a dealer. Those are steel keys and most locally cut keys are brass (weaker). I've never seen a steel key break off in the cylinder, but have seen several cases where a brass key has. In the general case, if you are breaking brass keys in the ignition the lock cylinder needs to be replaced. If the doors the cylinder or the latch could be the cause.
                • I<3BMW
                  • Jun 2012
                  • 121
                  ^^ correct.
                  • Fourbanger
                    • Jul 2011
                    • 335
                    Super easy on a late model, but I think I remember reading that you have to remove a panel or two to access the gloryhole on an early model.
                    • MoreMayhem
                      • Feb 2012
                      • 649
                      I found this not to be true, at least at my local dealer in California. Unless this is something totally new: I had them make a key from my VIN in April 2011.
                      • redsubdivisions
                        • Feb 2011
                        • 1762
                        copy of license and registration/title with your name on it and it gets ordered. I do it several times a week. Lol
                        1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                        2012 Passat TDI - DD Duty
                        2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                        • agent
                          Vice Grand Pubaa
                          • 7960
                          The answer is yes, and as stated by Jim and others the steel key the best option unless you have other failing parts. Mine came to me cut and ready to go.
                          Originally posted by kronus
                            Keys are cut at BMW's NJ facility I think. Take your license and proof of ownership to your dealer and they will order the key. Proof of owner ship is usually your registration for the car, but I have heard of dealers that required or proof of title. So take both.
                            • enigmaticdream
                              • Jan 2010
                              • 572
                              I got two brand new keys for my e30 m3 with VIN and registration.
                              OP, spend $50 on rebuild kits. They are worth the price and time spent rebuilding a cylinder. You learn something new and the car feels slightly more awesome.
                              This is all you need
                              1986 911 Supercharged Frakenstrat/Stripped
                              1987 325is Delphin/Black (Olga)
                              1988 M3 Zinno/Natur (Elsa)
                              Manual or STFU
                              E30 Chapter of BMW Car Club of America
                              E30 Oktoberfest 2017
