My 87 325is has good working heat while driving, but blows cold when the RPM's drop below 1500. Well, not cold, as the car doesn't have A/C, but it's no longer hot or even warm.
There is also a smell of coolant, most noticeable when I first turn the heat on.
The engine doesn't go past 1/2 on the temp gauge, and has a newer thermostat. The coolant system is bled, and stays at the full mark in the reservoir, and I've put a couple thousand miles on the car recently.
I'm having trouble thinking of a failure mode that would cause both of these symptoms: No heat at idle, and the smell of coolant. Ideas? I'm thinking I should replace the heater core and valve, as one of them has to be leaking to get that smell, and then just go from there.
