When applying a moderate counterclockwise torque (like lane changing to the left), I can hear and feel a strong vibration from the front right wheel.
No noise or other symptom when going straight or when turning more aggressively.
I stopped the car, jacked up the right side, and I could wiggle the wheel in yaw (i.e. steering) but not in roll (i.e. camber). I first suspected tie rod ends, so I cranked the wheel to the right. The tie rod end looks fine, but I can see the ball joint boots are torn wide open.
I plan on replacing the ball joints and tie rod ends, but I was just a bit worried that it could be a wheel bearing. Thoughts?
ETA: '88 325iS
ETA: '88 325iS
