Compression test
  • SpecM
    • Oct 2005
    • 4531
    ^ yes that is the correct test.
    -I would guess head gasket, tho.
    1989 cirrisblau-metallic 325i
    • PeaveyBassist
      • Sep 2004
      • 3511
      Jordan, that is what I thought. Thanks for the tip about testing the rings. Hopefully its head gasket or valve seating.
      Will
      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
      Welcome e30 (brilliantrot '90 325is) 12/23/06
      DaveCN = Old Man
      My signature picture was taken by ME! Not by anyone else!
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
      • RobertK
        Kicked cancer's ASS.
        • Jun 2005
        • 5864
        Originally posted by Jordan
        The easiest way to see what is causing the low numbers is to do another compression test as you have already done. Squirt ~tsp of normal dyno oil, thicker the better, into the cylinder through the spark plug hole. Give it some time to work its way around the rings. This will temporarily restore compression lost through bad rings.
        If your numbers come out good this time its your rings.. if not its likely bad valve seating or a blowing head gasket.
        I've heard of this trick working to check for bad rings but from the % in loss of compression I would definately rule out bad valve seating. My cylinder 3 has a worn valve seat and last time I did a compression test it only had about a 5-6psi difference from the rest of the cylinders, also, cylinders 2 and 4 were just fine.
        IMHO if you have the money and an extra beater to get around in save your money and have the head pressure tested, shaved (if nessesary), ported, polished, reseat the valves, and get the 3 angle valve grindage. The way I see it, there's only one way to do it and that's right the first time.
        • jht3
          • 288
          re-do the compression check with the oil trick
          do a leakdown
          these should tell you if its a ring, valve, or gasket failure. if its just the gasket, i'd pull the head, check the head for warpage, and put a full gasket set on. replace the chain, waterpump, and other maintenance items. no need for a head job on a high mileage daily driver (polishing a turd)
          if its a ring or valve issue, it might be easier to swap the motor out. its your call
          James
          '88 M3
          • PeaveyBassist
            • Sep 2004
            • 3511
            Well I was actually planning on getting rid of the car after I graduated school in a year. By then I was hoping to sell mine for a parts car and get a truck to use as a tow vehicle (story behind that one) and daily driver. If I end up not needing a tow vehicle, I might look into some small roadster ala the new MX-5. I really have no idea for sure what I am doing in a year car wise. I dont wanna spend all that money on this car. So... I am probably going to drive it as is for now for a beater. Just drive it till it blows up.
            Will
            DaveCN = Old Man
            • Dave
              E30 RAT
              • 11675
              That is a total shame, Will.
              Current Cars
              2014 M235i
              2009 R56 Cooper S
              1998 M3
              1997 M3
              • PeaveyBassist
                • Sep 2004
                • 3511
                Yes, I know. But the front end damage and now the engine problems. I mean... I can get a whole nother e30 for $2k. So... I dunno what I will end up doing. I really dont wanna do head work. And if I am going to go through the trouble of swapping engines, I would want one thats gonna last a while. So swapping in another "as-is" m20 would be gay. If the car dies, I would probably end up just doin just the gasket set for the top and change the head gasket. I just want this car to last until I can afford to get a $10-$15k car.
                Will
                DaveCN = Old Man
                • Dave
                  E30 RAT
                  • 11675
                  I don't blame you. I meant that its a shame that all this has happened.
                  Dont get in a bunch of debt for a car.
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • PeaveyBassist
                    • Sep 2004
                    • 3511
                    Exactly. I dont wanna have to go through all the trouble to fix it back to a decent condition again. I mean, I LOVE this car and if I had the money, I would throw it at the car with no second thoughts. And yea, its a shame all of this happened. If the front end damage HADNT happened, then I would probably be more abliged to fix the engine problem because it would still look pretty good on the outside. I dunno... I will figure somethin out.
                    Will
                    DaveCN = Old Man
                      • 34847
                      if your body is smashed, part it out and get another car. bad body + bad engine = parts car. :(
                      • PeaveyBassist
                        • Sep 2004
                        • 3511
                        Exactly nando :( Problem is... no where to part out. PLUS its my only car. So... the engine still runs and pulls decent actually. When I go down and see Dave I will give him a ride and let him feel what I am talkin about. Eventually if I sell it, it will be sold as a parts car.
                        Will
                        DaveCN = Old Man
                        • nefarious7907
                          • Jan 2005
                          • 1170
                          it looks like decent car although I havent seen pics of the front end. I wouldnt get rid of the car if the front end is in reason of fixing. If you get something else buy a car cover and park your e30 at your parents house somewhere, who knows you might have the funds to fix the e30 in six months and have anther car/truck. spending a thousand on repairs is better than spending 15k on a newish car.
                          http://www.cardomain.com/ride/657387
                          • RobertK
                            • Jun 2005
                            • 5864
                            QFT.
                            IMHO it would be better to sell this car for parts and buy another E30 than to payout $$ in interest and car payments. The difference is with a new car is that you will be paying out every month + gas + full coverage ins. as opposed to just paying for gas + liability and the occasional maintenance repair with a paid for used car. Atleast with the used car you can manage to retain some earnings between maintenance repairs. Car payments tend to be the mantra of the middle class these days.
                            • Dave
                              E30 RAT
                              • 11675
                              Will, I'll make you a really sweet deal on a silver car with bronzit bumpers. ;-)
                              Seriously, though, my GCs showed up today. I'll Pm you about getting together to wrench.
                              Current Cars
                              2014 M235i
                              2009 R56 Cooper S
                              1998 M3
                              1997 M3
