Need help removing key ignition cylinder.
  • Slc325
    • Apr 2012
    • 27
    I am about to purchase a new E30 project but the seller doesn't have the keys for the car. I have removed ignition cylinders before but never without a key. Just wondering if this is possible or what I need to do? I have tried searching but can't find anything. Thanks for the help.
    PS I am not trying to steal a car....
  • dnguyen1963
    • Nov 2011
    • 2649
    Get the VIN and go to the dealer with proof of ownership to get a new key. If you have not made the purchase then have the seller get the key for you.
    • dnguyen1963
      • Nov 2011
      • 2649
      If you don't want to spend money on a new key then your only option is to drill it out.
      • Slc325
        • Apr 2012
        • 27
        I didn't know this was an option. I'll try this first. Thanks
        • bmw325csi
          • May 2007
          • 4045
          Grab the trunk lock and go to a locksmith. He should be able to make you a key. Lets hope the locks match though.
          harry/harout
          • Slc325
            • Apr 2012
            • 27
            Good idea. I'll call a few locksmiths tomorrow.
            • dnguyen1963
              • Nov 2011
              • 2649
              Dealer will run you @ $65 for a key. I don't think locksmith will be cheaper, plus it might not work for the ignition.
              • bmw325csi
                • May 2007
                • 4045
                Locksmiths around here will charge about 10-15 bucks
                harry/harout
                • dnguyen1963
                  • Nov 2011
                  • 2649
                  Wow, that's cheap. Many locksmiths would not touch BMW locks around here.
                  • E30Linz
                    • Mar 2013
                    • 6
                    I got the key from the dealer but apparently the ignition and doors were changed by the previous owner, because the dealer key from bmw will not work on my ignition or doors! please tell me how to get it out so I can put my new one in!!!!!!
                    • E30Linz
                      • Mar 2013
                      • 6
                      can you explain to me how to drill it out?
                      • dnguyen1963
                        • Nov 2011
                        • 2649
                        This is a PITA of a job...
                        Disconnect the negative battery cable.
                        Using a 1⁄8 in. (3mm) drill bit, mounted in a right angle drive drill adapter, drill out the retaining pin, going no deeper than 1⁄2 in. (12.7mm).
                        Place a chisel at the base of the ignition lock cylinder cap and, using a hammer, break away the cap from the lock cylinder.
                        Using a 3⁄8 in. (10mm) drill bit, drill down the center of the ignition lock cylinder key slot about 1 3⁄4 in. (44mm), until the lock cylinder breaks loose from the steering column cover casting.
                        Remove the lock cylinder and the drill shavings from the housing.
                        Carefully inspect the steering column housing for signs of damage from the previous operation. If any damage is apparent, the components should be replaced.
                        Good luck...and keep in mind that this will take a long time to do. The metal is very tough!.
