lot of vibration when sliding in rain
  • iloveshaorma
    • Feb 2012
    • 59
    so...it's mostly wet this part of the month in romania and whenever i punch the throttle 1st and 2nd i get the tires to spin and jump a lot, it shakes my whole car really bad. it's like they get grip slip get grip slip and so on...what do you think the problem is? could it be the diff bushing? should i get a fixed one instead of rubber?
  • Nick325is
    • 1409
    It could be any number of things but the diff bushing or subframe bushings could be whats causing it. I had a similar issue a few years ago and it turned out that my differential bolts had come slightly loose. Tightening them up solved the problem.
    • e30 gangsta
      • 3877
      I get wheel hop in the rain even with all new bushings. Id suggest a bit more compression on your shocks.
        Likely causes would be bad subframe & trailing arm bushings, and blown shocks. Replace all of that along with the upper shock mounts, sway bar bushings and sway bar links.
        • AndrewBird
          The Mad Scientist
          • 11898
          Leaf spring swap?
          • mcaden
            • Jun 2011
            • 164
            What Nick said - check your differential bolts... same thing happened to me and resolved it (note: 3.73 LSD). After that check your bushings and (if you haven't done it within the last 30,000 miles) replace your diff fluid while your at it.
            Good luck.
            Marc
            • iloveshaorma
              • Feb 2012
              • 59
              Good luck.
              Marc
              it did that after changing the diff...so it seems that the rubber bushing is the culprit. i'll have to change it for a ceramic hopefully it will work out. thanks for the advice!:)
              • xtos
                • 81
                All cars do that. It really doesn't matter if you have a new car or a beat up car,Koni or Boge. If the wheels aren't spinning fast enough on good but wet asphalt you get the rear axle vibration. LSD does make it appear less though.
                1990 318is M-technik2
