I am trying to restore/swap an E30 with an OBD2 S52 and am in the wiring phase. I got the E30 without a drivetrain inplace so several things were unhooked. The portion of the harness that comes out from under the fuse box has three seperate sections: 1 is the C101, the second has a couple of large black wires with ring connectors, that look like grounds and a two pin connector, I have no idea what these go to. The third is cut off about six inches from the fuse box but it has two or three wires in the sleeve, again no idea what these are supposed to go to. Can anyone point out what these are? Thanks
Wires from the bottom of the Fuse Box?
Can you post a pic? Might be the pigtail for the aux fusebox- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plate
