Windshield wiper motor BAD.
  • Norwegian
    • Feb 2013
    • 255
    So my windshield wiper motor on my 89 vert is messed up, and needs replaced. Anyone know how to do it or how hard it is?
    It's raining a lot here in the south lately. So I need my wipers baby!!
  • berlow94
    • Jan 2013
    • 1063
    I'm doing a motor swap and still struggled for an hour to replace the motor with the engine out.
    Good luck with the engine in!
    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
    • steve68
      • Jan 2013
      • 457
      Sure it's not the switch in the column
      88 M3 Lachsliber glass top, 90 IS project,
      • Danny
        • 14216
        Watch the curse words in thread titles please.
        • jrobie79
          • Mar 2006
          • 2521
          the easiest way is to take the motor off the linkage...after you wiggle that out its like a half hour job. I tried it the other way (all together) solid 3+ hour ordeal. Get the ratcheting box wrenches from craftsman.
          that is exactly how it should be done
          1991 318i ---- 308K - retired
          • FLG
            • Sep 2011
            • 3165
            Once you understand it, its easy to get the motor out. The linkage on the other hand, has still baffled me....so i have my mono setup still not installed.
            -Build http://www.r3vlimited.com/board/showthread.php?t=295277
            • Todd Black 88
              • Oct 2007
              • 3449
              Linkage becomes very simple once you realize there are two clips that hold the back side of the blower housing in place. Remove the clips and the housing and it slides out.
              Originally posted by codyep3
              I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
              2001 silver/Blk 325 cabby. SOLD
              2002 325xit Sil/blk. SOLD
              2010 F650gs twin
                • 34839
                the motor isn't hard at all. unbolt it from the linkage, remove the plastic cover (you have to deform it a little but no big deal), unplug it. done.
                put the new motor back in, plug it in, put the cover back on, cycle it once before connecting the linkage, that's pretty much it..
                the linkage isn't hard either, as long as you're willing to remove the intake manifold to get to it. I just replaced mine last year, it finaly failed after 20 years in the rainy PNW.
                • Norwegian
                  • Feb 2013
                  • 255
                  Video
                  Here is a vid of my problem..
                  • steve68
                    • Jan 2013
                    • 457
                    ok, not the switch, sounds like the gears stripped,
                    • Norwegian
                      • Feb 2013
                      • 255
                      Yeah. Something. It works when I push it and force it, well you se in the vid. Damn.
                      • jrobie79
                        • Mar 2006
                        • 2521
                        new motor, mine was doing the same thing.
                        • Norwegian
                          • Feb 2013
                          • 255
                          How did you change yours out? Was is hard?
                          • Swanny
                            • Mar 2012
                            • 2834
                            Did it in my 87 IS this summer. took about 30 minutes and some monkeying around with a 10mm ratcheting wrench. If you need a motor I just happen to have one on my parts car! Can get a video of me removing it if that helps.
                            Swanny!
                            SUCKERS.
                            • I8UR911
                              • Jan 2013
                              • 260
                              Definitely a crap job especially if you don't have tiny hands. Getting under the motor to get the nuts really sucks. Once you've done it once it isn't awful, but your first time will take 1hr+.
                              Sent from my XT907 using Tapatalk 2
