At a somewhat predictable moment the window switches and blower motor will stop getting power. At slow speeds, this isn't much of a problem. At highway driving it flicks off and on. The power will come back on when I r3v the engine.
The car will not turn on if the window switch lights aren't displayed.
The problem has characteristics of a bad/loose/dirty ground, so I went through and checked/cleaned the grounds. There might be something going on with the starter ground as I have a few washers there. I also haven't found any loose or exposed wire.
It's not a major issue, but it is a bit annoying. Does anybody have any other ideas?
It is an m50 motor swap.
Thanks!
Thanks!
