"I" cluster in my es??
  • hashi
    • Sep 2012
    • 52
    So I have a 86 325es with a m20b25 in it and was wondering if a "I" cluster would work in it? Thank you for the help.
  • Killacortes
    • 1937
    Yeah but your fuel gauge will not read correctly
    r3v does not fuck around. First you get banned, then they shoot you
    • hashi
      • Sep 2012
      • 52
      Thank you so much!! For the fuel ill just set my trip meter when I fill up and problem solved!!!
      • M44schnell
        • Apr 2012
        • 123
        Please elaborate, i put the i cluster in after my 327i build.
        Dose it show high or low :eeek:
        I still have to get the tach working as well
        • reelizmpro
          • 9558
          It'll be alright if it's an 87 325i cluster. Otherwise, the fuel gauge should be swapped over.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • efficient
            • Feb 2012
            • 3312
            what if the little yellow light never comes on when on low fuel?
              That could be a bad bulb in the cluster or a bad low level switch in the level sensor.
