I was driving along with cruise on and suddenly cruise cuts off and at the
same time 55mph is suddenly only 42-44mph. cruise will not work anymore
the econometer only swings back and forth.
i pulled the speed sensor and it looked good as did the connectors going to
it. plus the speedo has to be receiving some kind of signal for it to work
all.
here is the thing though. i pulled the cluster to check for bad gears, burnt
connections, ect.... all the gears are in good shape no broken teeth or
anything even the odometer gears and my odo has never worked.
no obvious burnt spots and i did not go through the whole checking for
cracked solder deal(id rather just get a new cluster) and have no means to
reflow solder anyway. all the connections to the cluster were in good
condition.
so is it a speed sensor going bad in stages or the all-too-common bad
circuit connections in the cluster?
if it is the cluster would there be any way to make the cruise work with an
aftermarket speedo?
all.
condition.
aftermarket speedo?
