Oil in my spark plug wells
  • bannre10
    • Aug 2011
    • 18
    Hey Guys,
    Today whilst adjusting my valves (3000 k's after due because Im lazy) I found oil in the wells where the spark plugs connect to the leads. Am I right in thinking this means the gaskets sealing the plugs from the top of the engine are stuffed?
    If so are there any valve gasket kits that are good quality/ are there any I should specifically avoid?
    The car is a 91 318is and I'm located in Australia if that changes anything in terms of suggestions.
  • series88
    • Nov 2011
    • 1231
    Pretty much. I think the most commonly available gasket is victor reinz
    • e30 vert
      • Jul 2012
      • 67
      well seems like you have a m42 engine which i heard they dont need a valve adjustment
      someone correct me if im wrong
      if you want to change your gaskets victor reinz is the way to go
      • series88
        • Nov 2011
        • 1231
        ^they still do like most engines. Just not as needed as the m20s. (i think) Ive driven an adjusted m42 and my p.o.s and it does make a difference. :)
        • Fidhle007
          I can fly, motherfucker
          • Oct 2005
          • 7209
          How do you adjust hydraulic lifters...? Oil in your spark plug wells is due to a leaky valve cover gasket.
          '89 325is S50 Track Montser
          '04 X5 Daily/Tow Vehicle
          http://www.avarestoration.com
          http://www.myspace.com/brendanfiddle
          Click here if you want to be my zombie slave...
          http://www.youtube.com/user/Fidhle007
          • ELVA164
            • 4861
            He probably has an m40, which should have hydraulic lifters as well. You can adjust them, but they aren't supposed to need as many adjustments as standard valves.
            • Fidhle007
              • Oct 2005
              • 7209
              Wouldn't a '91 318s have an M42? Even down under?
              • blunttech
                • 12850
                in to learn how to adjust hydraulics
                sales@blunttech.com
                www.blunttech.com
                Like us on Facebook
                • Vtec?lol
                  • Dec 2009
                  • 3278
                  M40's aren't hydraulic. I thought they were belt driven SOHC. They aso have the plugs aligned to the side of the head.
                  Valves are adjustable.
                  • Fidhle007
                    • Oct 2005
                    • 7209
                    But they were only in early 318i and 316i cars. So the point is completely moot.
                    • andrewm
                      • 456
                      Run extremely thin oil
                      1987 Delphin 325e Sedan - Natalie
                      1990 325i 24v
                      1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
                      • Vtec?lol
                        • Dec 2009
                        • 3278
                        That is partially incorrect. they weren't only in early cars.
                        • ELVA164
                          • 4861
                          Foot-in-mouth moment. Turns out some motors have adjustment on the plungers but the M40/M42 don't. They use springs it appears. :???:
                          Dunno if a wiki is a good enough source, but http://84.45.115.78/e30zonewiki/index.php/M40
                          • Fidhle007
                            • Oct 2005
                            • 7209
                            I meant E30s.
                            • TobyB
                              • 5296
                              RealOEM is awesome. It lets me waste 5 minutes figuring out that, yep,
                              you COULD get an M40 in an E30,
                              but nope, it also has hydraulic adjusters on a pivot underneath the cam, like the later M44.
                              t
