M20 over heating issue
  • bmwguy325is
    • May 2011
    • 1263
    So as mentioned above you need to check the fan. The one attached to the water pump pulley. The main fan is powerful enough to cool the car properly at idle.
    However if your AUX fan never came on than it as well is fouled up.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • Shahriar35
      • Feb 2012
      • 91
      I believe it is the main fan. Did the roll of newpaper trick.
      Where can I get a new fan clutch from for a decent price and quicky? Autozone wants $92.... A bit pricey. I would like to get one tonight. Thanks
      • SmokeE30
        • 1730
        If you current mechanical fan passes the news paper test it would be safe to say that it's probably ok however you said turning the ac on to activate the aux fan cools it down so it could be a contributing factor. You can get a new fan clutch for around 50$ online but idk what stores In your area may have one available tonight
        Shawn @ Bimmerbuddies
        Bimmerbuddies LLC
        717-388-1256
        2971a Roundtop Rd, Middletown PA 17057
        bimmerbuddiesllc@gmail.com
        • 603Racing
          • Dec 2010
          • 612
          Sounds like a bad fan switch. That may not be why your car runs hot though. Like e30Gus said, could be fan clutch or water pump.
          When was your timing belt done last? Maybe time to go ahead and do a t-belt/water pump job.
          90 325i DD/Track
          03 Durango 5.9
          Originally posted by e30mpg
          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
          • fatsooo
            • 312
            Hopefully the t-belt and water pump was one of the first things you did when you got your car...
            But anyways depending on where you are in CA, pelican parts and bma have fan clutches for like 60 - 70 bucks and should get to your house next day if you order early enough. I'm in OC and usually get my parts delivered next day from both suppliers if I order early enough.
            Turner has it for a but cheaper, but takes a week to get delivered usually.
            If you're a stickler about your cooling system like I am, I would test that aux fan too. My switch went bad and its like $30 $40 to replace with new gasket ring too
            Sent from my SCH-I535 using Tapatalk 2
            • Shahriar35
              • Feb 2012
              • 91
              So here is the update:
              I did the fan clutch and it helped greatly, the new one of course passed the newspaper test. Now the problem is that it doesnt get cooler than 3/4. After the car is warmed up, it remains that high. As for the AUX fan, it never kicks on....
                Is that the gauge reading when driving at 45mph or greater? As a recap, at this point you have replaced the thermostat, fan clutch, and radiator with new, not used parts. Right? That being the case, I'd want an independent measurement of head temperature with a contact or IR thermometer. With the OE thermostat you should see ~176F.
                At speed the fans aren't what cools the engine, though they are important at low speed or when idling. The air flowing through the radiator does work.
                • Cephas
                  • Apr 2012
                  • 878
                  I would definitely check the temp with an IR gun. I went through a similar problem on my car and it ended up being the nut on the back of the cluster. It was loose and my temp gauge would creep up to the 3/4 mark. I tightened the nut on the cluster and voilĂ , problem solved!
                  • Shahriar35
                    • Feb 2012
                    • 91
                    So if the head temperature is around 176. What would the conclusion be? A issue with the gauge/cluster?
                    • Shahriar35
                      • Feb 2012
                      • 91
                      Which nut was it on the back of the cluster? I may check into that. Thanks
                      • Ceeker
                        • Sep 2009
                        • 2821
                        the nut behind the temp gauge loosens off in some cases creating a false reading on the temp. tightening it down will correct the problem. caused by time and vibration. put some loctite on it and you're done.
                        • Shahriar35
                          • Feb 2012
                          • 91
                          I just wonder if that is what my problem is. I just need to get my hand on a IR thermometer so I can see if my head is at the right temperature.
