Brake lights stuck on
  • assoutE12
    • Oct 2005
    • 694
    I noticed the other day that my brake lights were staying on when I took my foot off the brake. they will go off if I lift up on the brake pedal manualy.
    I searched and found the most common problem to be the brake switch. I was just inspecting it and it seems like the switch is working fine. If I depress the brake pedal with one hand and press the switch with the other the brake lights go off every time without fail.
    I tried spraying some grease on the bushing but that didn't help.
    anyone have any ideas what this could be?
    I was thinking the spring?
  • chuckybob
    • Aug 2004
    • 952
    BENdashdash had this problem, pm him and ask how he fixed it. id assume it has something to do with the brake pedal adjusting screw.
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
    • BENdashdash
      Tom is not my friend
      • Aug 2004
      • 2506
      Yeah, when I replaced brake light switches mine started doing that. Even when I used the old switch it still did it. I've dinked around in there a few times and still haven't found a solution.
      • DarkWing6
        • Apr 2004
        • 7144
        Must be your fuel lines.....:D
        • Jordan
          • 12913
          Bend the bracket until problem is solved.
          https://mtechniqueabs.com/
          • BENdashdash
            • Aug 2004
            • 2506
            I tired that but stopped because the CC switch was moving too much. I suppose it wouldn't hurt to try again. ty
            • assoutE12
              • Oct 2005
              • 694
              that was my first instinct, but i figured I should try to see if there was some sort of a proper fix it before I started to try and bend shit around.
              on a side note, I got your sub installed the other day and it sounds great. I am 100% satisfied with my stereo now.
              • assoutE12
                • Oct 2005
                • 694
                I spent a few minutes in the garage today and fixed my problem.
                All it took was a little love with a pair of chanel locks and now my brakes lights are working perfect. :woowoo:
                Thanks alot Jordan.
