kill me now
  • nickmp0wer
    • 1427
    kill me now
    well it looks like my head gasket is blown. The car over heated, and i still dont know why. IT barely got it to the red but it was enough to to it. Can anyone offer any advice before i tackle this job? Do i basiclly just need a head gasket set and head bolts? should i get it ported or anything while its out? I know i need to at least have the head checked for trueness or whatever. This seriously sucks so much fucking balls
  • bimmer8604
    • 3017
    :bang.
    It sounds like all you need is headgasekt. check the head and all that stuff. you have timing chains i believe so i wouldnt worry with those, and do the waterpump i gues.
    kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
    • PeaveyBassist
      • Sep 2004
      • 3511
      If you're changing the head gasket because it overheated... chances are, the head is slightly warped. Get it machined so its flat on the bottom.
      Will
      RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
      Welcome e30 (brilliantrot '90 325is) 12/23/06
      DaveCN = Old Man
      My signature picture was taken by ME! Not by anyone else!
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
      • 92 mtechnic cabrio
        • 4907
        as of this time you have 1337 posts.
        leet.
        too bad you're running into new problems every day with your car :(
        R.I.P 07/01/09 - 04/23/10 :(
        • nickmp0wer
          • 1427
          Will any brand gasket be fine or should i get one form the dealer? I think i will get a set from bma cause there are other gaskets that needs replacing also. I think the head is probably pretty fucked. I think it got a lot hotter then i relize. At idle the car would read around normal temps, and when i would drive it would get higher. Then i took the t-stat housinng off and it was dry in the engine cause all the coolant went through the exhaust. So think it was just reading the temps of the air comming from the combustion chambers
          • kowalski
            • Jan 2005
            • 1791
            just get the head machined and it should be fine. get a top end gasket kit, they're arround 100$ canadian... you can get a felpro one, they're good quality. and then just give the machinest the valve guides and the head, and get him to machine it (if it needs it) and then throw it all back together. headgasket kit 100$, head bolts <$20, machining arround 300$ (if it needs it)
            • Jordan
              • 12913
              Parts Car
              https://mtechniqueabs.com/
              • terrybpp
                • Sep 2004
                • 340
                Originally posted by Jordan
                Parts Car
                You should take you own advice.
                • Jordan
                  • 12913
                  Why? Nothing on my car ever breaks.
                  Nicks car falls apart on a daily basis even when he isn't driving it.
                  • trashcop 80s 80s
                    • Jun 2004
                    • 1130
                    your car was a parts car, until you spent your full year's salary on it
                    • Jordan
                      • 12913
                      I've still got <20k into this car.
                      I should hope anyone here on salary makes more then that a year.
                      • BahnE30
                        • 1050
                        shit, i thought we were actually killing him. fuck.....
