OK, I have redone all the front suspension (CA and CAB, Tie rods sway bar links and bushings) and balance the front two tires and a shop did all 4 wheels alignment.
Two items I suspect are A) warp rotors and pads and B) hubcentric rings.
The wheels bore is slightly larger that the rotors center.
I want to know what is the E30 center i read is 72.6mm but need to confirm
also what is the best way to check for warp rotors by feeling or what.
I found these hubcentric rings at ebay and want to knwo if these might work
http://www.ebay.com/itm/HUB-CENTRIC-...d7e736&vxp=mtr
