Just curious what octane are you using for your 325is? (87')
  • optimusp517
    • Oct 2005
    • 797
    I've been filling up with 91 cause I believe the manaul says it, but what does everyone fill up with? I live up here in the Pacific Northwest so I'm not sure if that has any effect on which octane I should be using.
    26
    91
    38.46%
    10
    89
    15.38%
    4
    87 (I don't think our car can take that, haha)
    46.15%
    12
  • AdamF 88iS
    • 2051
    91. Mine pinged with anything less around here.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
    • The Fast One!
      • Jul 2005
      • 856
      run mine on 87 ALLLL the time, no pings or anything, car runs great and fast.
      don't have 91 around here just 87, 89, and 93. should prolly put 89 in it just to be safe though.
      Mike Fritz
      • StereoInstaller1
        GAS
        • 22679
        Too much octane is bad. Higher octane ratings mean lower combustion temperatures: more unburned fuel. That is how detonation is controlled, by reducing temperatures in the combustion process.
        Read this http://auto.howstuffworks.com/question90.htm so you understand what octane means.
        M20's are a low compression ratio engine. Higher octane gas is a waste (and by "waste" I mean fucking stupid) unless you are chipped and have radically advanced your timing curve, or have a shaved head/block/different pistons whatever.
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • RobertK
          Kicked cancer's ASS.
          • Jun 2005
          • 5864
          Luke
          I use 93 religiously with 3.5 oz of Acetone to every 10 gallons in both of my cars. Unburned fuel is also caused by the surface tension of gasoline and how well it can be ionized.
          The acetone helps to break the surface tension of the gasoline much like how jet dry in your dish washer breaks the surface tension of water. It also causes much more of the gas to be ionized when injected into the combustion camber.
          • James Crivellone
            Head Janitor
            • 6305
            91 in mine, although I require it due to my Mark D Chip
            • PУCCKAЯ_e30ka
              • Jan 2006
              • 1226
              89, not too high, not too low
              • HST
                • Jan 2006
                • 757
                Originally posted by Ritalin Kid
                I use 93 religiously with 3.5 oz of Acetone to every gallon in both of my cars. Unburned fuel is also caused by the surface tension of gasoline and how well it can be ionized.
                I think he means 3.5 oz per tank.
                I do the same in my E36, 4 oz per tank.
                Originally posted by KingB
                Scratch my back and I buy a prostitute for you, to rub your balls. HAHA now thats some funny shit.
                • RobertK
                  • Jun 2005
                  • 5864
                  Fixt!
                  • e30Matt
                    • 5077
                    I run 93 due to the chip (JC). I wish we had something between 93 and 89 though.
                    • mspiegle
                      • 1026
                      If your car runs fine on 87, DO NOT use higher octane gas. It will eat up your cat faster, lower your gas mileage, and provide LESS power.
                      Michael Spiegle
                      '01 Ford Escape / Daily Driver
                      '99 M3 / Track Car
                      '87 325is bronzit / wtf car
                      '06 Daytona Triumph 675 / Daily Rider
                      • optimusp517
                        • Oct 2005
                        • 797
                        I'm going to give 89 a shot and see how the car runs... Just alwasy wondered even though the manual instructed 91 for the car.
                        • erik325i
                          • Jan 2005
                          • 3567
                          The manual does not call for any higher than 87 octane for 325s. Only m42 and s14 powered vehicles require 91 octane.
                          I only put 87 octane in my car. never had any problems with it.
                          -Erik
                          • Digitalwave
                            is a poseur
                            • 6299
                            How could you possibly need 93 octane and acetone on a stock M20?
                            RISING EDGE
                            • augusta325is
                              • Dec 2005
                              • 6
                              The manual says 91 but it does not mean 91 OCTANE. I use 87 all the time no problems and ALSO 3 oz acetone to every 10 gallons.... About 20 mores miles out of a tankful after I started it.
                              1990 Black 325is
