Hey guys,
I just got a quote back from my mechanic for what I need in order to pass roadworthy, bare with me as his handwriting is messy and I can't make out some of what he's written.
What I really want to know is, how much will parts roughly cost me in Australia and is it worth it, or will it cost too much and should I sell the car? Keep in mind I need to spend an additional $200-400 for the certificate and a further $500-700 on top for registration.
- Wiperblades
- Seat belt - "coucas to serouded" WTF lol
- Tailshaft coupling crack
- Engine oil leak ---> T/C Seal
- Rear box leak --> Extension housing seal
- Rear muffler (has a hotdog on it atm)
- Diff mount crack
- R/H lower rear bushing (2)
- R/H engine mount p bracket
- Rear trailing arm bushes (4)
- R/H rear tyre
- Air filter box hose filled
- Speedo (I believe the RPM and ODO gauges are playing up)
I also have a headlight issue, where the top part of my headlight will light up, but the bottom part won't - needs a new bulb? Also, my fog light doesn't light on the left hand side, bulb again?
In regards to the cluster gauges, I believe it may be related to a fuse as the radio, clock and above gauges all seemed to have started playing up around the same time with PO.
Thanks a bunch in advance!
- Wiperblades
- Diff mount crack
- R/H rear tyre
