bad trans causes high idle?
  • htown318is
    • Feb 2012
    • 301
    have an auto 89 325i, did all kinds of tune ups with filters, pump valve adjust etc. fixed my cold start issue, problem now is soon as I turn it on, it jumps around 1200-1500 in P, N D 321.
    when i put it in R, it goes back to normal 700 rpm. only R works on this trans. there are no functioning forward gears.
    kinda confusing, is there a sensor of some sort in the trans or computer that triggers this?
  • jeffnhiscars
    • Jun 2011
    • 6010
    There is no connection between your dead trans and idle..other than that putting it in a working gear will add a load that will slow your idle. First thing to do it check for intake leaks and a smoke test is the most effective way to do that.
    Alice the Time Capsule
