weird turn signal operation
  • EtaSport
    • 2853
    Recently my passenger side turn signals have become inoperative. The driver's side works perfectly fine, both lights coming on, blinking correct speed, indicator lamp lighting up, flasher click.
    The passenger side lamps do not come on at all, nor does the indicator lamp, but the flasher clicks fast like it does when a bulb goes out. Both the bulbs are okay. The hazard switch works just fine. All four lamps flash, both indicator lamps flash, and they all flash at the same speed. I have no idea what is going on.
    Old and improved:
  • Court M3
    • Jan 2004
    • 6713
    turn signal relay on the fritz? Check the bulbs again, mine had that problem once and one bulb was actually burnt.
    Continuous For Sale Thread
    323i s50
    • chuckybob
      • Aug 2004
      • 952
      fuse or wire
      : : 1984 318i : : PNW E30 Crew : : Sold!!
      Now becoming the R3vlimited Pro3 car
      http://www.r3vlimited.com/board/showthread.php?t=93780
      • lordofthewaters
        • Oct 2005
        • 714
        Could maybe be the switch too.
        Sarcasm is a body's natural defense against stupid.
        When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
        "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
        Old age and treachery will always overcome youth and skill.
        • EtaSport
          • 2853
          Should have clarified more. All fuses are fine, all lights are working, if hazards work, then the signals have to work as they are through the same relay (flasher).
          I am leaning towards the wire, but I hadnt even given thought to the switch itself. Thats probably it.
          Old and improved:
          • Bimmerfanatik
            • May 2004
            • 5349
            Ever solve this? My DS is doing the exact same thing - though sometimes it works perfectly, making things even more unusual...
            • chuckybob
              • Aug 2004
              • 952
              thats a short or a bad relay for sure
              • turnofftheradio
                • Apr 2005
                • 448
                sounds exactly like mine was. I replaced the switch/relay and it works fine. I thought for sure it was a short in the wiring, but it was an easy fix.
                • EtaSport
                  • 2853
                  It was the turn signal stalk switch. I was going to get one from the yard, but they were all faded and looked like crap, so we took the switch apart and cleaned all the contacts up and used some dielectric grease, never had another problem.
                  Old and improved:
                  • turnofftheradio
                    • Apr 2005
                    • 448
                    nice! free fix
                    • Bimmerfanatik
                      • May 2004
                      • 5349
                      Dang it, Already changed this once on this car - the last one always had the highs come on when you signaled. I'll try the relay...
