So I bought another car today, still have to go pick it up but I wanted to try to figure out what's up with a major fuel leak it's having. When you start it a massive fuel leak occurs under the drivers footwell, where the car sat I couldn't get a good look besides that a lot of fuel was coming out. Is there only hard line in that spot? Does it switch to rubber line there? I'm hoping it's not a rusty hard line and just a deteriorated rubber hose connection. I tried looking at realOEM with no luck. Anybody have a picture of this area or a similar experience?
85 325e, fuel leak under driver footwell
Shawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
2971a Roundtop Rd, Middletown PA 17057
bimmerbuddiesllc@gmail.comTags: None -
Yes. Most likely a split hose."I'd probably take the E30 M3 in this case just because I love that little car, and how tanky that inline 6 is." - thecj
88 M3 - LACHSSILBER
89 M3 - ALPINEWEISS II
91 M TECH CABRIO 2.7L TURBO - MACAOBLAU -
2 fuel lines and a breather line, all hard, run under the drivers door. OEM can get you new ones all bent and flared for like 30 bucks. New hose and body clamps are a good idea too. Replacing rubber lines while you're there wouldn't be a bad idea either.
When I did mine for reference, early model as well
Thanks for the pics, hopefully it's not to bad i hate dealing with rust hard lines, but if new ones are still available from BMW for a reasonable price I guess it's not to bad. Hopefully I can get a friend with a trailer to pick up the car soon so I can get it up in the air and really see what's going on under thereShawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
bimmerbuddiesllc@gmail.comComment
This just happen to me and it was definitely the rubber fuel feed lines that go from the hard lines through the engine bay. I knwo this cause I could feel a bunch of fuel on the hoses when I dipped my hand in below the master brake cylinder reservoir.
Remove fuse 11 and start the car... this is the fuel pump so you can depressurize the lines. When it dies, you can remove the hoses and replace them, one goes into the intake manifold, the other one believe goes int other charcoal canister. It's probably one segment of the line but to be safe these all should be replaced. Another leak and your car could go up like a roman candle so there's no reason not to replace some rubber hoses. Check the current hoses but they are probably 8mm high pressure fuel hoses.Last edited by FasterSoonerNow; 05-07-2013, 05:31 AM.Comment
