Thanks for the help.
So where is the fuse link on a vert since the battery is in the front?
Understand but the CEL went out. Has not come back on since nor has the problem reappeared. Still want to find the problem as I don't view the vehicle as reliable as it is.
So an interrupt or weak reference data could make the tach bounce. Typically tachs I've seen bounce due to ignition cutout go all the way back to zero when they bounce. This was doing that. It's stopped now.
The engine harness is original. If I replace it, what am I replacing? Is there a part number? I assume there are many things that plug into the engine harness. Start at point A and work your way to the end of all the various splits.
Originally posted by jlevie
View Post
View Post
View Post
View Post
