Last weekend I made a trip to Chattanooga to grab a hood from rs4pro3 and we got there I could smell raw gas under the hood. We noticed very small leakage from the return line when it was clamped to the FPR so Eli gave us some fuel line to replace it on the spot. In the process I noticed that it might have been seeping out around the o-ring to the FPR and a little bit of stainage around fuel injector #6 (the one closest to the FPR).
After doing some daily driving this week I popped the hood because I was smelling faint raw gas smells again when I turn the car off. It's very hard to tell except for where the gas looks to be staining the paint on my intake a brownish-yellowish color now around injectors 5 and 6. (The two closest to the FPR). I can't really tell if it's leaking from the o-ring @ the FPR either.
I guess what I'm getting to is if this is a sign that my FPR is going? Is it possible that the FPR is causing fuel pressure spike which is causing small amounts of gas to seep out around the o-rings of the 2 injectors closest to it?
