help on my 318 1984
  • fishmanlarry
    • Jan 2006
    • 1
    help on my 318 1984
    My car stalls out, I replaced wires & spark plugs, rotor & cap,fuel filter. Most the time it runs great. Then while driving it acts like its getting no gas.
    Wondering if anyone could help.
    Thanks
  • rs4pro3
    • 5808
    have you checked the distrubuter timing, or fuel pressures?
    85 325e 2.7 ITB'd stroker
    • Charlie
      kid tested, administrator approved
      • 6686
      I'm gonna say dying fuel pump or a short to it.
      -Charlie
      Swing wild, brake later, don't apologize.
      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
      FYYFF
      • chuckybob
        • Aug 2004
        • 952
        it seems like every 84 318i is set to self-destruct at 22 years.... my car has the same problem, at this point in time, it seems to be the afm. i think kencopperwheat's has a similar problem, you should ask him if the afm has fixed his problem. another 84 318i on another message board is having very similar symptoms, his problem has been diagnosed as a lack of fuel. another 84 318i on that other messageboard has been down a list of 8 or 10 defective parts and still has those symptoms.
        best advice: check the bentley and troubleshoot from there, once you figure out what the problem was, post back here with the solution so other people can gain from your experience.
        : : 1984 318i : : PNW E30 Crew : : Sold!!
        Now becoming the R3vlimited Pro3 car
        http://www.r3vlimited.com/board/showthread.php?t=93780
        • 318driver
          • 1714
          yup, thats me.
          Car was studers and bucks only at random mostly cold times. and then all of a sudden it died. Changed both full pumps, ended up being the inline fuelpump. so the car no longer dies, but still has the studdering problem.
          90 325is
          IE stage 3s and refeshed m20....
          • lordofthewaters
            • Oct 2005
            • 714
            Have you checked the fuel pump regulator?
            Sarcasm is a body's natural defense against stupid.
            When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
            "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
            Old age and treachery will always overcome youth and skill.
            • 318driver
              • 1714
              fuel pump regulator? do you mean fuel pressure regulator??
              ive changed mine
              90 325is
              • lordofthewaters
                • Oct 2005
                • 714
                Yeah. Typed the wrong thing........again...........
                • chuckybob
                  • Aug 2004
                  • 952
                  Originally posted by 318driver
                  yup, thats me.
                  THATS YOU?! i was thinking of the guy who has the porche in his sig. jesus, im about to sell this thing and get a toyota.
                  • lordofthewaters
                    • Oct 2005
                    • 714
                    Where are you and how much? ;)
                    • ///M Powered
                      • Jan 2004
                      • 1109
                      add one more to the random studdering.. i've replaced just about everything but the fuel pump, it feels like it does it more when it's real cold outside or when i'm getting low on fuel maybe?
                      What's weird is sometimes when i feel it hesitating i'll give it a good downshift and it'll disapear the rest of the drive. Hopefully it magicaly fixes itself by next autox in march :(
                      • chuckybob
                        • Aug 2004
                        • 952
                        oh god, were dropping like flies. run the afm test first, if downshifting "solved it", its almost definetly something related to engine speed or load. if you have money to throw at it or enough to do some "preventative maintenance", try a new fuel pump and see if that does it. have you replaced your fuel filter yet?
                        • ///M Powered
                          • Jan 2004
                          • 1109
                          tried swapping afm's , new fuel filter/fpr/ icv/ all the lines/ took apart the whole intake mani and replaced all the gaskets/ plugs , wires, cap, rotor , I'm running out of thigns to check haha.
                          • 318driver
                            • 1714
                            have you changed the cold start valve?? others are pointing to that now?
                            90 325is
                            • ///M Powered
                              • Jan 2004
                              • 1109
                              yeah i read that in the other thread, and I'm not sure if he's referring to it being hte cause of it dieing, or hesitating( maybe both?)
                              I'll have to check mine out, it does rev really high when i start my car, maybe it's getting too much fuel...?
