Car on the blink (literally)
  • MrK
    • Jan 2006
    • 709
    I was starting my car this evening, and it starts up fine, but as soon as I switch on the lights and stereo, the rpm wanes to about 500, and everything electrical in my car blinks a few times in rapid succession and then the car goes dead. I was able to avoid this by keeping revs up the next time I turned it on, but the whole car still 'blinked' at random every 10 minutes or so while I was driving.
    My battery is new, 75AMP (66 is the standard)
    I'm running HID's
    I'm running a high-compression engine.
    I'm assuming that my alternator is quitting on me... any second opinions?
    This is your M20 on steroids:
  • PeaveyBassist
    • Sep 2004
    • 3511
    Alternator... OR... belt could be slipping on it real bad. See how bad the belt is.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
    • MrK
      • Jan 2006
      • 709
      Belts are all new, tightened to spec. Probably the alt then. Thx Will.
      • Jordan
        • 12913
        You should have a 650-725 CCA battery...
        https://mtechniqueabs.com/
        • PeaveyBassist
          • Sep 2004
          • 3511
          Do you know what the battery voltage is with the car running? Should be around 13.5-14.0v If its under 13, new alternator.
          Will
          DaveCN = Old Man
          • MrK
            • Jan 2006
            • 709
            Turned out to be a loose alternator wire. My alt was putting out 13.94V so I'm good. Thanks for the feedback.
