Idle Prob
  • mitch500
    • Jan 2006
    • 1092
    Idle Prob
    i have a 1987 325 just curious if anyone knows problem but it does this.
    i will start it up fine in the morning the rpm's will jump to about 650. after about 5 min driving or when the vehicle is warmed up the thing starts to idle anywere between 1000 - 1800 rpm's thanks.
    1988 e30 alpine white vert 5speed
    1987 e30 325 eta
    1983 e28 533
    2001 x5 4.4l
    1997 e36 M3 Alpine white 5speed
    1991 Jeep XJ I6 4.0
  • asubimmer
    • 6482
    icv?
    • Jordan
      • 12912
      is it a 325i or a 325e?
      https://mtechniqueabs.com/
      • mitch500
        • Jan 2006
        • 1092
        325 m20 2.7l
        1987 e30 325 eta
        1983 e28 533
        2001 x5 4.4l
        1991 Jeep XJ I6 4.0
          • 37828
          Moving this to the CORRECT forum, thanks
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • mitch500
            • Jan 2006
            • 1092
            does anyone know
            1987 e30 325 eta
            1983 e28 533
            2001 x5 4.4l
            1991 Jeep XJ I6 4.0
            • skatefreak
              • Jan 2006
              • 116
              My 87 325is did something like that until I swapped for the 173 ecu and 89+ idle control valve and intake elbow.
              • Brew
                • 3060
                Possibly the 02 sensor. Disconnect it and see if the problem goes away.
                '91 318is
                • bddog
                  • 351
                  Maybe some idiot turned up your throttle set screw?
                  • RobertK
                    Kicked cancer's ASS.
                    • Jun 2005
                    • 5864
                    Sounds like a vacuum leak.
                    • arsevader
                      • May 2005
                      • 1025
                      vacum leaks would be more of an issue when it's cold than when the car has warmed up.
                        • 37828
                        If the idle screw was touched the car would always idle the same ;)
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • mitch500
                          • Jan 2006
                          • 1092
                          so im pretty sure its the idle air stabalizer will one work from a 83-87 533i they look exactly the same.
                          1987 e30 325 eta
                          1983 e28 533
                          2001 x5 4.4l
                          1991 Jeep XJ I6 4.0
                          • BahnE30
                            • 1050
                            check the part numbers, realoem.com, is your friend, if they are the same then they will work.....
                            • Alluvium
                              • Feb 2006
                              • 42
                              i have that too when i drive my car hard sometimes that happens
