Car not starting I'm stumped
  • Bimmer_man
    • Jan 2013
    • 1477
    I have relaxed both of my cars fuel pumps the relays click the fuel pump one clicks numerous times. I can't find anything via Google search. The car has spark and it seems like the system is getting pressure. I know for a fact it's not the computer I have a spare and it still dosnt start.
    What's been done
    Brand new fuel pumps
    New ignition system
    Relays checked ( it clicks a lot)
    Ecu checked
    What are your suggestions
    Float like a cadillac sting like a Bimmer!:)
  • Dj Buttchug
    • Jun 2010
    • 7681
    what engine...? cranks but does not start?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Bimmer_man
      • Jan 2013
      • 1477
      Cranks just no start and it's a m20b27
      • Dj Buttchug
        • Jun 2010
        • 7681
        is fuel getting to the rail?
        Ig:ryno_pzk
        • Savagefurai
          • Apr 2011
          • 970
          My car had a similar problem recently. Had fuel spark etc...
          Ended up being the wiring to the injectors.
          Check your injectors with a noid light.
          Hope this helps.
          Currently without an e30. Will probably die soon.
          • Bimmer_man
            • Jan 2013
            • 1477
            From what i can tell yes it's getting toothed rail
            • mikeedler
              • 6707
              CPS or injector harness is corroded. would be my 2 guesses.
              • Dj Buttchug
                • Jun 2010
                • 7681
                what does this mean? does this mean you pulled the return line to check?
                Ig:ryno_pzk
                • Bimmer_man
                  • Jan 2013
                  • 1477
                  Yeah fuel is getting to the rail. I pulled the line off and checked
                    Fuel reaching the rail doesn't necessarily mean that the rail pressure is correct. Tee a gauge into the rail supply line and see what the pressure is while cranking.
