What's wrong with my speedometer?
  • m3/e30fanatic
    • May 2011
    • 2969
    I want to know what part has gone wrong and what I need to change, or even if its a fuse. My speedometer doesn't work but at times it'll jump up and work for a second then go back down. Also my odometer doesn't work. I don't know if that matters. Someone please help. Thanks in advance!
  • ivangene
    • May 2013
    • 41
    try these
    • jink0619
      • 808
      My speedo does the samething, kinda annoying, let me know if u get it figured out, ill do the same.
      E30love
      • Gregs///M
        • Mar 2012
        • 2459
        First change your old fuses with new. Do 10, 21, and 12. All 7.5 amp.
        Next is to check your connector at the speed sensor in the rear differential. It must be very clean and very secure.
        Owner - Bavarian Restoration
        BMW and European Electronics Repair and Restoration
        www.BavRest.com
        My Feedback Thread
        Our Facebook!
        Follow our Instagram!
        • ME30W
          • Feb 2012
          • 811
          I had the same problem when it rained. Speed sensor was having problems in the wet, put a new one in and POOF! problem is gone.
          I like cats.
          • jink0619
            • 808
            I solved my problem, my speedo did the exact thing you describe and i fixed it today by pulling out the plug that plugs to the speed sensor. I pinched the connectors pins with pilers so that it plugs into the sensor for a tight fit.
            E30love
            • Victor_PR
              • Jun 2011
              • 296
              ^^^ I did this today and so far it's working. I even put my new gears in I had bought a couple of months ago. While the speedo dissassembled on the bench with the new gears it worked. When installed they didn't. :(
              I'll wait till I have to remove the cluster again (a job I don't like to do) to tackle the problem. For now, I don't have to guess how fast or slow I'm going! :D
              Victor
              Rides...
              E30 325i - 1990
              F30 328i - 2014 (DD)
              F25 X3 - 2016 (Family car)
              1974 - 2002 (The ruler of the stable) SOLD
              • jink0619
                • 808
                nice! i figure since its jumping it has to be a bad contact problem, and since then i havnt had no issues.
                E30love
                • Gregs///M
                  • Mar 2012
                  • 2459
                  For the odo gears,
                  Loosen the screws for the plastic cover a bit. Just barely tighten them, if too tight, gears won't turn.
                  www.BavRest.com
                  My Feedback Thread
                  Our Facebook!
                  • thomascurry
                    • Jun 2013
                    • 1
                    Sounds like the simple connection problem. Did You get it checked. Show it to some mechanic and try for repairing. If doesn't works get the meter changed.
                    Bed bug extermination nyc
                    • Pete_E30
                      • Jan 2011
                      • 78
                      Same problem - the wires from the sender to the speedo had got brittle and broke off. Ran a new wire and it was as good as gold
                      '90 BMW E30 318is
                      '99 Honda DC2R
                      • jink0619
                        • 808
                        awesome! that seems to be most of our speedo problems
                        E30love
