since so many of us are having the same problem, i thought itd be best to put everyone's stuff in the same thread so that we can figure out what's going on and how to fix it.
Symptoms: seemingly random stalling, sometimes acompanied by hesitation and a required cooldown time before the car will turn over or run again (10-20 min). stalling is temperature independant.
Parts that people have replaced so far, with no affect on this issue:
spark plugs
spark plug wires
cap & rotor
FPR
Coolant temp sensor and connector
both fuel pumps
fuel filter
fuel pump relay
oxygen sensor
afm
parts that are likely to cause the symptoms:
icu
loose wires
csv
**FIXES**
ecu
spark plugs
spark plug wires
cap & rotor
FPR
both fuel pumps
fuel filter
fuel pump relay
oxygen sensor
afm
icu
loose wires
csv
**FIXES**
ecu
