Weather Stripping Issue
  • BENdashdash
    Tom is not my friend
    • Aug 2004
    • 2506
    I replaced the rubber weather stripping that goes around the doors on my cabrio. For some reason, the doors wont shut all the way now unless I SLAM them. And they're somewhat stuck when I try to open them. What gives?
  • chuckybob
    • Aug 2004
    • 952
    its probly not on there tight enough
    : : 1984 318i : : PNW E30 Crew : : Sold!!
    Now becoming the R3vlimited Pro3 car
    http://www.r3vlimited.com/board/showthread.php?t=93780
    • BENdashdash
      • Aug 2004
      • 2506
      Its on as tight as it can go. I just want to know if anyone has had a similar issue? It really shouldnt be an issue to begin with.
      • erik325i
        • Jan 2005
        • 3567
        First check the obvious. Is there anything in the way that would interfere with the door being able to close? Is the door panel clipped in properly?
        You might just have to adjust your door. If you move that hook type thing that the door latches on to, you can adjust how hard you have to slam the door to make it close.
        -Erik
        • NC325iC
          • Mar 2004
          • 6565
          is it the windows, wehn you put the new window seals in did you adjust your window properly?
          • BENdashdash
            • Aug 2004
            • 2506
            Ehh, the only thing on the way of the doors is the rubber on the weather stripping. The windows are fine. Its hard to shut even with the windows down. I'll take pics tomorrow if I get time.
            • BENdashdash
              • Aug 2004
              • 2506
              The doors are getting easier to shut, I think its something to do with the rubber getting shaped to my car. They still arent as easy as they used to be, but I'll give it some time. Thanks.
