Clutch pedal switch
  • blauplow
    • Mar 2012
    • 71
    Clutch pedal switch
    Does any body know if the physical switch the clutch pedal makes when it is in its normal position is used for anything? Mine makes an annoying clicking sound so I just want to disable the damn thing.
    The switch is part of the cruise control.
    • blauplow
      • Mar 2012
      • 71
      So I should be able to just keep the switch pushed in?
        Well you could do that, but if you ever depress the clutch while cruise is engaged, the engine will rev to the limiter. I've never noticed a click from the the clutch or brake pedal switches. Perhaps a new switch would help.
          • 34839
          if you push in the switch your cruise control won't work.
          why don't you just replace it?
            Nope, the switch must be depressed for cruise to engage. Cruise disengages when the clutch pedal arm moves away from the switch and allows the switch to open.
              • 34839
              yeah, you're right. still - it's a simple switch to replace and not that expensive.
