alternator internet myth?
  • 2761377
    • Jan 2011
    • 399
    found this little gem while searching to buy a new voltage regulator.
    "OK here's an easy one that I did once. You know that alternator idiot
    >light in your dash? If that bulb is burned out your alternator won't
    >charge the battery. Check the light and make sure it is working..."
    has to be true if it's on the internet, right?
    thanks,
    robert w.
  • LJ851
    • 7919
    Depends on how the light is wired. Some cars are the way you describe.
    Lorin
    The M30 is God's engine.
    • TobyB
      • 5280
      After about 1987, BMW put a resistor in there to prevent just that.
      Your ETM will tell you if you have one or not.
      t
