Vibration/Grinding? at highway speed, goes away when turning left
  • MattPro
    • Dec 2010
    • 502
    I'm trying to diagnose a weird vibration issue with my vert and could use some help.
    The problem:
    Starting at around 50mph I start hearing a sound that gets louder with speed. The best way I can describe it is as a tire sound, it sounds like the sound your tires make when you go over certain patches of highway, but much louder. It is almost like a grinding but I'm hesitant to say that.
    I can feel a vibration in the steering wheel but it's nothing terrible.
    The weirdest part is that if I turn left on the highway, there's a certain steering angle that if I hit in the turn it will completely stop. Once the steering wheel reaches that point, the noise instantly cuts out and the vibration goes away as long as I stay past it. When I return to that point to come out of the turn it instantly kicks back in again.
    I've been able to search for other threads with issues like mine but I haven't found anyone who has described the steering behavior. I'm hoping this will point to something obvious that I don't know about.
    Thanks
    Thanks,
    Matt
    Check out my BMW Fault Code Index
    '89 Turbo M20 Zinno Cabrio (scrapped)
    '89 Zinno IX (sold)
    '91 Granit Turbo S52 Sedan (scrapped)
    '91 WIP (scrapped)
    '13 F10 Carbon Black 550iX MSport
    '91 iX Sedan
  • Pdxseth
    • May 2012
    • 3124
    Maybe a wheel bearing or a broken belt in a tire.
    • Brezzi
      • Jan 2010
      • 1630
      See what rotating your tires around does. it sounds like its more than that but you will at least rule out bent/out of balance wheel/tire issues.
      • MattPro
        • Dec 2010
        • 502
        Thanks for the suggestions.
        If anyone searches and comes to this thread sadly my car was hit by a dump truck yesterday so I probably won't be able to find out what it was it for a while if at all ever so sorry to be no use.
        Thanks,
        Matt
        '89 Zinno IX (sold)
        '91 WIP (scrapped)
        '91 iX Sedan
        • dnguyen1963
          • Nov 2011
          • 2651
          so sorry for your loss!
          • Pdxseth
            • May 2012
            • 3124
            Damn!! Pictures?
            • Northern
              I like cupcakes & sh!tboxes
              • 5265
              For future searches, this sounds exactly like the dying ds front wheel bearing issue I'm having right now.
              Originally posted by priapism
              Originally posted by shameson
