rough running with lights on?
  • uglyveedub
    • Apr 2009
    • 90
    1990 325is 5 speed, engine stock.
    So I have been looking for an answer as to my current situation. Used my car to jump start another car a few months back, it developed an odd problem.
    It will start, idle, run out fine until I turn on electrical accessories, then it stumbles and sounds like its missing on 2 or 3 cylinders but it comes back at WOT. Its hard to drive at WOT around town...Headlights, wipers or hvac blower trigger this.
    Had battery tested, wouldnt hold charge. I have swapped to a tested good battery/alternator/oil pan to chassis ground. Made sure to ground the alternator to engine block as well(newer reman unit)
    Drives great until it gets dark or rains or is cold. Please offer some suggestions. Thanks in advance
  • manpie
    • Sep 2007
    • 251
    Is the car an automatic?
    Ignore that question. I can't read.
    • dnguyen1963
      • Nov 2011
      • 2651
      Check the voltage regulator on the alternator. It might be going bad.
      • trashycamaro
        • Feb 2011
        • 70
        AutoZone/Advance auto parts will check your alternator for free. I was having similar issues and we isolated the alternator before it killed the battery.
        1991 e31 - Black on Black, 5.0L/6 Speed. Sold
        1990 e30 Cabriolet, 2.5L/auto. Sold
        1999 e39 Touring, 2.8L/auto. Sold
        1988 e30 Cabriolet, 2.5L/5 Speed. Going for retro modern convenience driver.
        • oliver.r
          • Mar 2012
          • 3839
          sounds like your voltage regulator
