Water dripping out of vent?
    On my passenger side vent water drips out when my ac is on? Is this just condensation from the ac lines or something else?
    Smell like freon? Can you see where its leaking?
    Might be an O ring/seal.
    BLUE NOSE - M62 SWAP
    THE E30 + 1 BUILD
      I doubt it's refrigerant since it boils as soon as it sees the atmosphere it could be condensation but it should drain from the evaporator outside the car make sure that's not plugged
      1989 BMW 325is Lachsilber metallic 5 speed
      2007 BMW 335i KARMESINROT 6 Speed manual
      2011 BMW X5 35I
        Maybe the heater core is leaking and the stream is condensing in the vent? We are taking about the dash vents, right?
          Thanks for the help guys And it's the vent in the bottom of the passenger footwell
            That could be clogged drains.
              Whats the easiest way to unclog the AC drain ? I suspect mine is partially blocked since a lot more water drains out the bottom of the car when parked which suggests it accumulates while Im driving.
              Alice the Time Capsule
                I know one things for sure, if its the drivers side... Most likely the heater core valve... My buddies blew and showered him with hot ass coolant. Talk about a fun drive.
                THE E30 + 1 BUILD
                  You'd likely smell antifreeze if it was heater related. The evaporator housing drain hose does appear to be on the drivers side just above the gas pedal....and of course behind the centre console. This doesnt mean a clogged drain wont cause water to come out the passenger side unless you only make right turns :-)
                    Did you resolve this? I get water in the car when the AC is on, same location, passenger side up near the forward section of the center console. I'm wondering if the drain is leaking.
                    90 325i DD/Track
                    03 Durango 5.9
                    Originally posted by e30mpg
                    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                      Find the evaporator drain under your car... not sure where it is on e30's, but I'm sure the internet does. Take a straightened coat hanger or something like that and shove it in the drain - try to unclog it.
