What could it be?
  • danalyse
    • Apr 2009
    • 153
    What could it be?
    Went to get a haircut today and got into the old Beemer, drove for a couple hundred feet and poof...it died. Crank, crank, and crank but no start. A little sputter after substantial cranking but would not start. Pushed the car and a good Samaritan fellow Beemer drive stopped to help. Both of us were to old to push on this 90 degree day but we did into a nearby parking spot. Came back in a few hours and it starts right. Throws the 1223 code which is a coolant sensor issue. Disconnected battery and reconnected it and the code has been cleared. Any ideas?
    Vapor lock is what I was thinking.
  • efficient
    • Feb 2012
    • 3312
    battery ground clean or loose?
    • FLG
      • Sep 2011
      • 3165
      Grab a multi meter and ohm out your coolant temp sensor. Not sure off hand what spec is but a quick Google search should provide answer.
      Sent from my Galaxy Nexus using Tapatalk 2
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • Holland
        • Nov 2008
        • 7212
        Can always be a possible fuel pump as well.
        Originally posted by DEV0 E30
        • Quinthirty
          • Mar 2012
          • 318
          Vapor lock.
          • dnguyen1963
            • Nov 2011
            • 2651
            Beemer = BMW motorcycle
            Bimmer = BMW car
            • e34_spangler
              • Dec 2012
              • 311
              Bimmer = BMW car
              :thumbup: noobs:p
