Easiest Way to Install New Aux Fan
  • mcaden
    • Jun 2011
    • 164
    After troubleshooting electrical issues related to my aux fan, I finally got it working correctly last night. That bliss lasted for about about 20 or 30 minutes whereupon the fan motor seized and blew the #3 fuse. So, I am going to be replacing the aux fan.
    I have seen some people suggest the aux fan can be replaced without removing the radiator. What is the easiest route? Can I remove it by taking out all my grills and lifting up and out? My car is a 1987 325ic.
    Thanks for your thoughts.
    Marc
  • mr.vang
    • 4371
    Remove the bumper and valance. After that just unscrew and pull.
    • mcaden
      • Jun 2011
      • 164
      And will it come out up thru the hole where the grills go or downward?
      • jeffnhiscars
        • Jun 2011
        • 6010
        I just replaced my condenser and aux fan without removing the valence or bumper. I removed the 2 bolts that hold the valence to the body near the bumper brackets and that gave me enough wiggle room to swap fans. The write up is in the last couple of posts in my red Cabrio barn find thread in my sig
        Alice the Time Capsule
        • jamessssbond007
          • Jul 2013
          • 1
          hi
          welcome to this forum site, here you can find lots of
          thing, I suggest you for your question you have to
          contact any other expert right now, I am not able to
          give you answer sorry for that....
          top ten classified website
          • mcaden
            • Jun 2011
            • 164
            Jeff,
            Thanks for your response! It didn't make sense to me that the front bumper needed to come off. It is easy enough to take the front valence off... I am mainly glad I don't have to drain and remove the radiator.
            All the best.
            -Marc
            • mr.vang
              • 4371
              Originally posted by mcaden
              Jeff,
              All the best.
              -Marc
              Show me show you removed the valance without removing the bumper?
              • jeffnhiscars
                • Jun 2011
                • 6010
                Jeff,
                All the best.
                -Marc
                Marc..I did not remove the valance but again, just removed the 2 valance to frame bolts near the bumper shocks to gain 1/4" of flex in the valance. Be uber careful as it is aluminum and will distort if you talk mean to it.
                Once you remove the lower spoiler ( 2 ABS pcs on my car), headlight surround and kidneys it will all be accessible
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  The front valence is not aluminum, it is steel, just like the rest of the body.
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    hats good since its less likely to deform. Either way it doesnt have to come off
                    • mcaden
                      • Jun 2011
                      • 164
                      Just to circle back with folks here. I removed my aux fan this weekend by simply removing the lower plastic black valence underneath my 1987 E30 325ic. However, my oil cooler was in the way. By removing a couple of brackets holding the oil cooler in place... you can swing the oil cooler out of the way and the aux fan will drop straight down/out. Unfortunately, I couldn't install my new fan because all three of the mounting bolts (shouldered fit bolts) were boogered up.
