M50 question
  • 325 eta
    • 472
    M50 question
    what header do i need to use. when it comes to puting a m50 into a e30
  • rwh11385
    lance_entities
    • 18403
    m50 exhaust manifolds. needs attention/work to clear control arms (or something like that)
    • Brian 89 325i
      • 1450
      From what i heard you can use most any M50 manifold thats not a full length header but the DOWN pipes need changing to clear the control arm. DONT QUOTE ME ON THIS THOUGH. If im wrong please correct me.
      Brian
      • JasonH
        • 434
        Brian
        Brian is correct. The down pipes require a little cutting and welding, but any of the stock manifolds work. Get the the M52/S52 tubular style manifolds and create two small block off plates for the OBD-II emission equipment that you won't be using.
        • 325 eta
          • 472
          thanks i want to get all my parts ready for the swap. also please recommend a good cd that will explain most of my questions, i hate bugging you guys with every little problem that arises with my swap.
          thanks ,
          eric
          • Brian 89 325i
            • 1450
            What about after market shortie headers like the Bimmerworld ones? WIll they fit with custom down pipes?
            Brian
            • e304eva
              • 13
              Brian
              make sure you weld the passages between cylinders shut on the back of the header flanges if you use them
              • Brian 89 325i
                • 1450
                Which passages are you talking about? What are they for? And are these only on the stock manifolds?
                Brian
                • Stu Mc
                  • 4083
                  Don't waste your time with shorty headers, they don't do shit on M/S50's. Stock M50 manifolds are all you need. If you can, get '96-on manifolds, which are stainless, and 8 pounds lighter.
                  • SlammedE30
                    • 741
                    If you want a parts list give Precision Performance a call, they can tell you everything you need. Stu can help you out with contact info.
                    -Ted
                    • bimmerphile
                      • 3495
                      Check out this thread:
                      Very full of info
