carbon platinum 4's in two days
  • Racer@heart
    • Sep 2005
    • 87
    i have a 325e that fouls its plugs in 2days or less... no matter what i use... the fuel system has been replaced and or cleaned the shit out of... the wires cap and rotor have been replaced... ummmm... the computer has been replaced... and i am getting ready to replace the FI coolant temp sensor... and thats all i can think of... i have a, well what was a good running parts car... its been stripped to get this one on the road... anything else i can replace to possible fix this problem... and no i am not selling the parts car when i am done... it is getting a s62 but i need to get this one running first...
    '84 318i
    '87 325is
    '86 325is
    '89 M3
  • permit
    • Mar 2005
    • 3363
    Have you only tried platinums? Platinum spark plugs suck, find just stock replacements.
    • Racer@heart
      • Sep 2005
      • 87
      these are the bosch platinum 4's and to my understanding one of the best plugs to buy for your beemer... and i have tryed stock replacements... they lasted less then a hour of attempted tuning... the 4's last almost 2 days
      '84 318i
      '87 325is
      '86 325is
      '89 M3
      • Rob
        • 8166
        what kind of setup are you running that fouls plugs so quick?
        BEERTECH
        • Racer@heart
          • Sep 2005
          • 87
          stock... thats why i am confused...
          '84 318i
          '87 325is
          '86 325is
          '89 M3
            • 34844
            you sure there's not something mechanical wrong with your motor? IE blown rings, leaking headgasket, etc?
            • Racer@heart
              • Sep 2005
              • 87
              positive compression tests check out and exhaust is clear...
              '84 318i
              '87 325is
              '86 325is
              '89 M3
              • bimmer8604
                • 3017
                ditch the platinums, get the stock copper plugs, and put in a new FPR.
                see if that works.
                kyle
                1988 M3, 97 840, 99 XJ
                DILLIGAF
                • Racer@heart
                  • Sep 2005
                  • 87
                  the fpr is new...
                  and copper plugs burn better then platinum in e30s?
                  '84 318i
                  '87 325is
                  '86 325is
                  '89 M3
                  • permit
                    • Mar 2005
                    • 3363
                    Originally posted by Racer@heart
                    the fpr is new...
                    That's what I was trying to say. Plantinum plugs are no good for Bimmers.
                    • bimmer8604
                      • 3017
                      platinum-garbage. hence go to copper.
                      kyle
                      DILLIGAF
                      • Racer@heart
                        • Sep 2005
                        • 87
                        whats a good copper plug to use?
                        will platinum cause a plug to carbon in a day?
                        '84 318i
                        '87 325is
                        '86 325is
                        '89 M3
                        • bimmer8604
                          • 3017
                          when you pull your plugs out do they smell like gas? or are they oily? if they are black andoily, you are getting oil in your combustion chamber, which could be like a faulty PCV system or bad rings maybe. just get bosch coppers, not sure of the number on the top of my head.
                          kyle
                          DILLIGAF
                          • lordofthewaters
                            • Oct 2005
                            • 714
                            Bosch wr9ls
                            Beru 14 R/9 LS
                            Sarcasm is a body's natural defense against stupid.
                            When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
                            "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
                            Old age and treachery will always overcome youth and skill.
                            • Racer@heart
                              • Sep 2005
                              • 87
                              ok my plugs are carboned over... do you all know what i mean by that...? theres no oil or anything else on them they are powdery and black... sooty even i believe it is caused by overheating of the fuel and combustion system due to a bad FI coolant temp sensor... but i was wondering if there is anything else that can cause that... if spark plugs is it then that great problem solved... but if the plugs i am using are fine. what else can cause this problem, if my engine checks for mechanical problems check out...
                              '84 318i
                              '87 325is
                              '86 325is
                              '89 M3
