Vac Leak Brake Pedal
  • e30 gangsta
    • 3877
    Hey guys i can here this vacum leak when im driving. I turn the car off and i hear air hissing really loud. I hit the brakes and after about 2 pumps the hissing goes away. Where do you think this air is leaking from? What line? part number would be helpful. And would this vac leak have anything to do with how the motor runs?
  • bimmer8604
    • 3017
    usually in the brake booster its either the diaphram is cracked, or the vacuum check valve...
    realoem doesnt allow the hosting like that.
    Kyle
    1988 M3, 97 840, 99 XJ
    DILLIGAF
    • e30 gangsta
      • 3877
      ok so im looking to replace the valve and lines. When u say the diaphram is cracked you mean on the actual brake booster?
      • Digitalwave
        is a poseur
        • 6293
        There are 4 bolts that the pedal box bolts to, and those 4 bolts go to the brake booster. Make sure all 4 of those are tight. I had the same problem after my tranny swap because I didn't tighten them enough. They are hard to get to.
        RISING EDGE
