Hello.
I need help from you guys.
My temperature needle is almost always shacking...
I´ve search the forum, and jordan once said to tight the bolt and i´ve done it, and no good.
I´ve cleaned the integrated circuit where are the batteries, and still no good (the first time i turned on the car, it was better), but now (2 times later), it´s the same... shacking.
I´ve disconnected the sensor near the thermostat and the needle dropped to 0, and after connecting, back to where it was and still shacking.
What may be the problem?
Problem with the Gauge?
May i put a 316i temp gauge there to replace mine(320i)?
would it work?
ground problems?
Help....
i´m thinking of buying an independent one (like VDO), to get a private reading of the temperature...
Thanks
would it work?
ground problems?
Help....
Thanks
