Oil in my Coolant tank?
  • Ryan///Mpower
    • Jan 2006
    • 29
    Last night I found what I think is oil in the coolant tank. I installed a new head gasket about 7,000 miles ago and also performed a coolant flush about 3,000 miles ago and everything was fine. Could I have a cracked head? Thanks for the help guys :up:
  • kansas-ix
    • Jan 2004
    • 1600
    head gasket failing?
    E30 325ix 62k
    • Ryan///Mpower
      • Jan 2006
      • 29
      I was told to do a valve adjustment after the new head gasket was installed but I never got around to it would the cause the head gasket to fail?
      • Jordan
        • 12916
        No.
        https://mtechniqueabs.com/
        • Dave
          E30 RAT
          • 11675
          Wow - what a question. Did you install the head gasket or pay a shop? If it was a shop, I'd take it back to them.
          Current Cars
          2014 M235i
          2009 R56 Cooper S
          1998 M3
          1997 M3
          • Ryan///Mpower
            • Jan 2006
            • 29
            Btw the car is running perfect. Heat works fine and the car does not over heat.
            • Ryan///Mpower
              • Jan 2006
              • 29
              Good friend helped me install it. I ruled out an install problem because he has worked for BMW since the 2002 came out and is a great tech.
              • PeaveyBassist
                • Sep 2004
                • 3511
                Cracked Head
                Will
                RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                Welcome e30 (brilliantrot '90 325is) 12/23/06
                DaveCN = Old Man
                My signature picture was taken by ME! Not by anyone else!
                If people keep quoting me in their sig, I'm going to burn this motherfucker down.
                • Ryan///Mpower
                  • Jan 2006
                  • 29
                  Originally posted by PeaveyBassist
                  Cracked Head
                  Will
                  I hope not :( the sad thing is you might be right.
                  • Digitalwave
                    is a poseur
                    • 6299
                    A car with a leaky or blown headgasket isn't necessarily going to run bad or overheat.
                    RISING EDGE
                    • PeaveyBassist
                      • Sep 2004
                      • 3511
                      He replaced the headgasket 7k miles ago though so it SHOULDNT be leaking.
                      Will
                      DaveCN = Old Man
                      • Ryan///Mpower
                        • Jan 2006
                        • 29
                        Cracked Head
                        Will
                        You were right I found out this weekend I have a cracked head :-(
