Cluster issues, Tach and MPG intermittent SI Batteries are GOOD?!?!
  • Jdesign
    • Jun 2012
    • 198
    I have just removed the Cluster from my car thinking that the Si Board batteries were dying. I had symptoms of an intermittent Tach and the MPG gauge right below it. Oddly the tach doesn't cut out once it is working. It seams that if the car sits for a long period of time (between 2-3 days indoors of coarse) is when I have the problem. I noticed that once the tach works sometimes the MPG gauge will kick in shortly after(with in a few mins) and not exactly the same time as the tach, but they have both kicked on at the same time before. I have this problem for the first few minutes of starting the car all the way to two hours of driving. The Other issue that really has me puzzled is that the Oil check LEDs wont reset. I have reset them in the past without issues. Now they are stuck on amber and wont reset, another reason which made me believe the batteries were dead. I took pictures of my SI board and the batteries which I can post if needed but they look like they are in unbelievable perfect showroom shape.
    I read on here about others that had similar problems but would also have issue with their temp gauge leading me to a simple solution of replacing the SI board batteries. Well I dissembled the Cluster and tested the batteries. Perfectly fine! 3.13 volts for one battery 3.12 for the other.
    so now what?!?!I don't want to replace the board because it looks mint! Any help would greatly be appreciated!!!
  • Jdesign
    • Jun 2012
    • 198
    Anyone? HELP!
    • dnguyen1963
      • Nov 2011
      • 2651
      Get the board under a magnifying glass and check for cracks in the solder.
      • Jdesign
        • Jun 2012
        • 198
        I did. It looks spotless.
        • Jdesign
          • Jun 2012
          • 198
          This is all I have for images right now but I will take more tonight. I sat and inspected the board for at least 10-15minutes
          • Poorboyz
            • May 2012
            • 2117
            Check the main boards solder where the tach mounts to. You might have to reflow the connections.
            Sent from my Galaxy Nexus using Tapatalk 2
            Rebuilding since 07/06/2016
            Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
            Poorboyz Feedback Thread
            • Jdesign
              • Jun 2012
              • 198
              will do!!! Thanks.
              • Jdesign
                • Jun 2012
                • 198
                I think I found my problem!! Poorboyz youz duh man!!!
                Look closely ay the solder connections. I missed this as I was inspecting the SI board looking for issues.
                • Gregs///M
                  • Mar 2012
                  • 2459
                  I'm willing to bet that your SI board batteries are still dead or will die soon. They are close to 25 years old!
                  New batteries have about 3.3 volts. Also a voltage test is not conclusive, you must do a current load test which measures the battery capacity. This can only be done by removing the batteries from the board.
                  Good job on finding the damaged solder joint!
                  Owner - Bavarian Restoration
                  BMW and European Electronics Repair and Restoration
                  www.BavRest.com
                  My Feedback Thread
                  Our Facebook!
                  Follow our Instagram!
                  • dnguyen1963
                    • Nov 2011
                    • 2651
                    It looks like the OP has a replacement SI board already.
                    • Gregs///M
                      • Mar 2012
                      • 2459
                      naw, the batteries are marked may 1989. You can always tell if they are OEM with that amber colored glue between the batteries.
                      www.BavRest.com
                      My Feedback Thread
                      Our Facebook!
                      • jhaurimn
                        • Nov 2012
                        • 2224
                        Honestly, if you are having tach mpg issues, it's probably the si boards as Greg said. Solved my intermittent issues
                        Current:
                        1989 325i
                        1988 M3
                        1987 325ic
                        Past:
                        2001 330ci
                        2001 M3
                        • Jdesign
                          • Jun 2012
                          • 198
                          Thanks for the response. You are most likely right. I just tested for voltage not the load. I have fixed the solder joint an still have the problem :/
                          Its most likely a stock board, just in really really good condition
                          I know, I just don't want to spend $200 on a new board. I Also want to find the actual problem rather than just replace it, if that makes sense?
                          • Gregs///M
                            • Mar 2012
                            • 2459
                            My boards are only $90 for r3v members. You can even send your old board back for a $15 credit.
                            www.BavRest.com
                            My Feedback Thread
                            Our Facebook!
                            • Jdesign
                              • Jun 2012
                              • 198
                              Sounds like a good deal... I will PM you!
