Wiper fluid won't spray
  • jhaurimn
    • Nov 2012
    • 2224
    Hey guys, first off I know there are threads on this but I've replaced the common items and its still not working. Kind of threw parts at the problem stupidly.
    Anyways, I've replaced the wiper fluid motor, the t valve, and the wiper stalk itself. The wipers work when I push up or down on the stalk , which makes me believe the relay and fuse is okay. But the wipers don't activate and fluid does not spray when the stalk is pulled back.
    Obviously there's an electrical issue, if someone can give me any tips to track down the problem that would be great .. Thank you!!!
    Jon
    Current:
    1989 325i
    1988 M3
    1987 325ic
    Past:
    2001 330ci
    2001 M3
  • mohamed...
    • Oct 2012
    • 577
    Mine had the same problem. I just took the washer fluid tank out and called it a day. Cleaned up the bay.
    E30 M30 B35 Swap Mounts!
    http://store.garagistic.com/ocart/e3...=5475809a87e04
    • dnguyen1963
      • Nov 2011
      • 2649
      You need a new relay...the big black one in the fuse box.
      • dnguyen1963
        • Nov 2011
        • 2649
        If the new relay does not help then you'll need a new stalk.
        • jhaurimn
          • Nov 2012
          • 2224
          Can the relay still be bad even though my wipers work at all? I've pulled the relay and the wipers don't work at all. Keep in mine the wipers work when I push down on the stalk but not when I pull back.
          And I said I replaced the stalk.
          Current:
          1989 325i
          1988 M3
          1987 325ic
          Past:
          2001 330ci
          2001 M3
          • dnguyen1963
            • Nov 2011
            • 2649
            Yep, I had one bad relay that caused intermittent problems. Sometimes it sprayed and other times not.
            • dustyperez
              • Feb 2012
              • 390
              there is a check valve along the line that gets plugged up as well
              • jeffnhiscars
                • Jun 2011
                • 6011
                Originally posted by jhaurimn
                Can the relay still be bad even though my wipers work at all? And I said I replaced the stalk.
                Its more like a wiper module than a relay since it manages different functions so its entirely possible for some to work and others not. If the stalk is "known good" then swap in a known good relay and you will have your answer.
                The check valve is in the T on the ones Ive seen
                Alice the Time Capsule
                • jhaurimn
                  • Nov 2012
                  • 2224
                  So i might as well bump this. Guessing its an electrical gremlin? Great because I have no idea how to tackle that. But heres what I replaced with new or known working parts-
                  Wiper fluid motor
                  T valve
                  Wiper stalk
                  Wiper relay
                  Fuse is okay
                  So im guessing somethings up with the wiring ? I need to learn the concepts of tracing power through wires. If anyone wants to chime in with some tips id appreciate it!
                  Current:
                  1989 325i
                  1988 M3
                  1987 325ic
                  Past:
                  2001 330ci
                  2001 M3
                  • Poorboyz
                    • May 2012
                    • 2117
                    I'm guessing that you are listening for the pump motor when you pull back on the stalk? Can you hear pump come on at all?
                    I had a similar problem where mine would spray either but I could hear pump motor come on...the hose came undone in one of the nozzles and was spraying fluid on the inside of the hood between hood and liner.
                    Sent from my Galaxy Nexus using Tapatalk 4
                    Rebuilding since 07/06/2016
                    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                    Poorboyz Feedback Thread
                    • M-technik-3
                      • 18946
                      Does the pump have power? Whhen the stalk is pulled?
                      • jhaurimn
                        • Nov 2012
                        • 2224
                        Yes I listened for the pump when i pull the stalk and it doesn't come on . I replaced all the hoses so I know everything is connected .
                        At this I'm almost positive power isn't getting to the pump.
                        Current:
                        1989 325i
                        1988 M3
                        1987 325ic
                        Past:
                        2001 330ci
                        2001 M3
                        • BlackbirdM3
                          • 2771
                          I'll bet one of the wires for the pump motor is broken. I chased this issue for awhile till I found the broken wire right at the plug. I haven't figured out how to fix it since there isn't any wire coming out of the plug to splice on. I haven't really worried about it since I've never owned a car with a working windshield washer setup.
                          Will
                          '88 BMW M3
                          • jhaurimn
                            • Nov 2012
                            • 2224
                            Originally posted by BlackbirdM3
                            I'll bet one of the wires for the pump motor is broken. I chased this issue for awhile till I found the broken wire right at the plung. I haven't figured out how to fix it since there isn't any wire coming out of the plug to splice on. I haven't really worried about it since I've never owned a car with a working windshield washer setup.
                            Will
                            I hear ya. It's not a big deal but I think it would be nice in the winter ;)
                            Current:
                            1989 325i
                            1988 M3
                            1987 325ic
                            Past:
                            2001 330ci
                            2001 M3
