Car doesnt start in hot weather, key doesnt crank over
  • Flash
    • 691
    I have four ignition switches, late car with the later style snap on switch
    i find it hard to believe that four switches, while all used and that were from running cars have the SAME exact problem....
    With that said, connections from positive and negative on the batter are good, triple checked, use wheel bearing grease on the terminals, battery is nice and strong. It will start up when cold fine but after the sun has come out it dont click, doesnt turn over, no cranking whatsoever. What the hell is going on? I am seriously frustrated.
    When you jump the diagnostic connector it turns over and fires nice and strong as a bad ignition switch would indicate. Though i refuse to believe four switches are bad and have the same issue.
    Please help :(
  • Boostesi
    • May 2011
    • 220
    I have almost the same issue except I bypassed my ignition switch completley to check and my motor will crank a half revolution then stop. Sometimes 4 or five times in a row then it will crank like normal again and start
    sigpicFellow e30 enthusiast
    Dont waste your time hating, aint nobody got time fo dat
    1986 bronzit 325es- SOLD
    1987 delphin 325i- parts car
    1990 scwarz 325is- m50 drift slut
    CHECK OUT THE BUILD!
    http://www.r3vlimited.com/board/showthread.php?t=229234
    • Boostesi
      • May 2011
      • 220
      With the push button or the key
        Since the starter will operate from the diag connector, there is some problem in the branch of that circuit that goes to the ignition switch. A bit of work with a test light will tell where the problem is.
