Quick Question on the C191 (injector to ecu plug)
  • 702pjc
    • Sep 2012
    • 143
    I'm looking at removing the connector and just adding new bullet male/female connectors. I just need to know what size of gauge to buy. Any ideas?
  • vpilarrt
    • Jun 2006
    • 2096
    The wire size is shown in http://wedophones.com/BMWManualsLead.htm next to the wire in question. I found 5 of the 7 wires going to C191 and they were either 1.5 mm^2 which is close to 16 AWG and .5 mm^2 which is close to 20 AWG.
      • 34839
      the small pin size will work fine
      • 702pjc
        • Sep 2012
        • 143
        Alright cool... Now, does anyone have the correct wiring info?
        I know the harness has 7 wires due to the unused ground on the CTS but I'm curious as to which color is the one I don't need to use.
        The coolant temp sender has two wired coming out of it. A yellow/brown and a brown/pink. The info on this link states that this combo is not possible...
        The only wire I find missing on the engine side is the smaller gauge brown/yellow but the link says that it should be used?
          • 34839
          Use brown/purple
          • 702pjc
            • Sep 2012
            • 143
            Thanks nando.
            Now that I've gotten it all crimped/soldered one of the smaller gauge wires decided to break out of the crimp... I bought the removal tool for the terminal but it won't work on this specific terminal... It's stuck!
            So is there any possible way for me to splice this ground (orange/brown) into another ground wire or do the grounds need to go back to their respective pins on the DME?
            edit: Nevermind, A little more elbow grease and it popped out. However, feel free to answer this for future viewers who may have the same problem.
