Coolant bleeding on M42 car with e36 radiator/tank
  • irish44j
    • 2763
    I just swapped an e36 radiator into my e30, which has an M42. Anyhow, the M20 bleed procedure includes the bleeder valve on the thermostat housing, but the M42 has no bleeder valve there (since the M42 rad has its own bleeder). So with neither of those bleeders available, any tips/suggestions on the best process to bleed the system most efficiently/completely?
    btw, expansion tank is located on the driver's side fenderwell pretty much where it is on the M20 car, but on the opposite side. It is higher than the rad/engine.
    Any thoughts welcome.
    Stage rally/rallycross e30 build/competition journal
    Track/street e21 build
    visit Condor Speed Shop
    visit Motorsport Hardware
    [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
  • Danny
    • 14216
    Bleed it like an s50 swap. Leave the cap off the expansion tank, get the car to temp with the heater on high then massage the upper and lower rad hoses to help burp the thermostat open. Add coolant as needed. Drive around the block, let it cool down and then do it again.
    Works every single time on my s50 car. Never had an issue.
    • irish44j
      • 2763
      Thanks Danny. That was about the only thing I could think of but didn't know if the "jack up the front of the car" or other tricks came in handy here. Luckily I have full coolant in the engine itself so shouldn't be too bad after filling the rad via the upper hose.
      • TobyB
        • 5234
        The e36 rad has a bleeder screw in it...
        ...at least, mine does, in the e36 I drove in today.
        t
