sea foam can go basically anywhere you want to put it, dont know how it can do that but they say it can
How to get the Gunk Out of my Engine.
why doesnt he just do one bottle to each areaOriginally posted by cahomeyGo to Napa autoparts, buy your self two bottles of sea foam. Put half in your crankcase, suck the other half through your vacuum line. Then repeat with the second bottle. Then change your oil and filter.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
Just put a quart of tranny fluid in the engine oil and run it a for 100 miles then drain and put fresh oil in
'87 325 (Track Rat)
'04 C5500 Wrecker (Work)
'94 525i (Daily)
'90 325i (R.I.P)
H&R Race, Racing Dynamics Sway Bars, Tree House CAB's, Sparco Strut Bars and more.Comment
ATF has properties similar to brake fluid. Most hydraulic fluids tend to be corrosive. I'm not to sure if I would want something like that touching the internals of my engine.
My ex-roomate did this to his old 86 Porche 924 and it's never ran straight since.Comment
Well, brake fluid runs through metal lines in many cars into metal calipers with metal pistons. You bleed it through metal bleed screws. Where's the problem?Originally posted by Ritalin KidATF has properties similar to brake fluid. Most hydraulic fluids tend to be corrosive. I'm not to sure if I would want something like that touching the internals of my engine.
"See, we're adding a little something to this month's sales contest. As you all know, first prize is a Cadillac Eldorado. Anyone wanna see second prize? Second prize is a set of steak knives. Third prize is you're fired."Comment
tranny is alum and steel too???Originally posted by e30MattWell, brake fluid runs through metal lines in many cars into metal calipers with metal pistons. You bleed it through metal bleed screws. Where's the problem?
Unlimited Slip Diff's FTW!
1972 240z Drift,Scca BSP, Scca ITS Car.
I believe that hydraulic fluid is corrosive to certain metals. Most of the hardware in a brake system is brass for a reason even the bleed valve is brass.
When my ex-roomy finally decided to get rid of his Porsche it was because his uncle (who is a very experienced mechanic) said that his injectors were fucked and his so were his rings most likely because he put ATF in his gas tank. Something one of his stupid ass redneck buddies told him to do.
Check out some links I've read on the subject:
Read Myth #12:
Seriously, go buy some Rotella 15W40 heavy truck oil. Lots of detergent for cleaning out carbon deposits and sludge. Run it every other oil change, you'll notice a difference right away. The pickup I owned for three months in the summer was dog slow, did an oil change with the high detergent oil, and bingo, fuel effeciency rose and power increased big time.Comment
