Bad ignition coil?
  • LateFan
    • May 2013
    • 4432
    Bad ignition coil?
    My coil numbers are:
    .9 to 1.2 ohms from + to - (it cycles up and down as far as .7 to 1.5)
    5470 ohms from center post to +
    Bentley says .5 ohms and 5000 ohms, and to replace if higher primary or secondary resistance.
  • vpilarrt
    • Jun 2006
    • 2096
    Did you have all the leads disconnected when making the measurements?
    • LateFan
      • May 2013
      • 4432
      Yes, all leads taken off.
      • TobyB
        • 5296
        it's fine.
        Short your ohmmeter leads together and see what that reads.
        Then take a reading with them on the same terminal, but in
        different locations on that terminal.
        You'll see what I mean.
        t
