help me find my oil leak
  • ky0u
    • Dec 2012
    • 808
    I have an oil leak somewhere and I can't find the source. Top of the passenger side control arm is coated in oil from it. Any ideas?
    Web Designer / Front End Developer
    My Portfolio & Website
    IG: @w_illriderz
  • Balleristic31
    • Aug 2009
    • 4198
    Oil cooler lines
    -NICK
    • jalopi
      • 2370
      Clean everything off. Look for oil on the clean surface... works like a charm every time. If you're still having problems, some parts stores actually sell a florescent dye that you can put in your oil - works best with fresh, clean oil though. Obviously you'll need a UV light and yellow goggles to take that route... but it does work well.
      • Dj Buttchug
        • Jun 2010
        • 7688
        ^ clean first and then start looking. Its so much easier to find these when the area is pressure washed clean.
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • Chuck C
          • 104
          Oil pressure switch. Unplug the switch, start the engine, and look for oil coming out past the electrical pins.
